How to use Read-only Mode
Return to support library
Sometimes, you may want to read your notes without the risk of accidentally editing them. That’s where Read-Only Mode comes in. This feature allows you to scroll through your notes distraction-free, perfect for reviewing and reflecting.
Enabling Read-Only Mode
- Open the note you want to set to Read-Only Mode.
- Tap or click the ⫶ menu in the top-right corner of the editor
- Select “More > Make Read-Only”
- A read-only icon will appear in the top-right corner to indicate the note is now locked for editing
Disabling Read-Only Mode
When you’re ready to make changes to your note:
- Tap or click the read-only icon in the top-right corner
- Select “Make Editable”
- You can now freely edit the note as usual
Why Use Read-Only Mode?
- Avoid accidental edits when scrolling or reading through your notes
- Stay focused while reviewing your ideas
- Perfect for sharing notes without worrying about unintentional changes
