Hey there, how can we help?
Popular searches: Sync, Bear Pro, Migrate
How to encrypt and lock notes with Bear
As of Bear 1.7, Pro users can encrypt individual notes. This helps protect them from nosy coworkers, family, and even us! Just like your notes, your Note Password is known only to you—we cannot see or reset it.
Encrypted notes only display titles (if available) in the Note List; previews are obfuscated even if a note is unlocked.
Add a Note Password
Follow instructions below to add a Note Password for encrypting notes in Bear.
Important note: If you opt to use Face/Touch ID, Bear will securely store your Note Password in the device’s Keychain.
iOS
Mac
Password best practices
When you pick a Note Password, a strength meter will encourage you to pick a strong password, complete with a helpful Password Judgemoji!
We highly recommend picking a strong but memorable password. Here are some tips to help:
Change Password
If you need a new password for any reason (we don’t judge!), it’s easy to change.
iOS
Mac
Remove Password
You can remove a Note Password from one or multiple notes.
iOS
Mac
Encryption and backups
When creating a backup of your Bear notes, encrypted notes will be included with all the others. They will also be encrypted in backup form.
If you need help on how to backup your Bear notes or your entire devices, there’s a blog post for that.
Limitations of encrypted notes
Delete Password Mode (extreme recovery - use with caution!)
If you forget your Note Password, we cannot retrieve or reset it, and we cannot recover your locked notes. While this situation is unfortunate, it is also done in the name of privacy: we don’t want to see your notes, tags, or any other data.
Delete Password Mode is an emergency solution for when a Bear user forgets their Note Password, but they want to start over and lock new notes. All existing locked notes must be deleted in order to use Delete Password Mode.
Here is how it works:
Bear should no longer have a Note Password available for locking notes. The next time you try to lock one, you’ll be prompted to set a Note Password just like the first time.
More about Bear'encryption
For more in-dept information about how Bear's encryption work please check this page.
Contact Us
